1966 Kiekaefer Mercury 500 Problems
elitearmymsg
I have a question/problem cant find a wire diagram for it cause it has both a pull and electric start has 2 chokes one on the motor and the other is a lever on the control unit also has a kill toggle switch no key start, push button start last owner messed it up
all it does when you try to start it cold it cranks and starts but after i run it a bit and shut it down and try to start it again it cranks just wont start and drains the batteryi have found a few wiring diagrams but none that are like mine
elitearmymsg
no name on the control it has a white body with black levers and my SN is 1895462 I looked it up and its a 1966 i think Canada built
elitearmymsg
its a warm up lever it looks like an old style merc control with no choke or key just a kill switch for the motor
