coolpapagwl
Thread starter- Joined
- Nov 1, 2003
- 2
I inherited this boat and motor last year. We have had it in the water several times with the only problem being that it was slow to go into forward gear. Yesterday it would engage in forward, but just stay at a idle speed when you increase the throttle. The motor responds correctly, but it still stays at a idle speed. Reverse works perfectly.<br /><br />We have checked to make sure that it is getting power to the lower unit from the connections at the back of the motor. Both the forward, and reverse wire connections recieve power when put into the correct gear.<br /><br />Out of the water we have engaged the forward gear without the motor running, and turning the prop by hand works the same manually for both forward and reverse so everything seems fine.<br /><br />Any ideas will be greatly appreciated. Not sure what to check next.
