1966 Johnson Motor
KCFNTC
I recently took possession of a 1966 Johnson 100 hp motor with tilt. Unfortunately previous owner twisted the control cable and separated the wires inside. Can anyone advise which wire goes where? It is a three wire unit. Thank you.
brodmann
Control cable with only 3 wires? I'm not sure I know what you're talking about. Pics, where does this "cable" originate and end?
Bo’sun
Hi, I just joined up here and this is my first post.
I retrofitted an early power tilt to my '65 Johnson 75 HP. I believe I have the parts catalog and it may contain some wiring info. I will look it up on Sunday.
The wiring is pretty dead simple I think. The panel switch has momentary up and momentary down with center detent. Probably one wire is 12V hot, and the other two are the switched legs for "UP" or "DOWN".
Bo’sun
Here’s the ‘65 parts diagram.
