I've aquired a 1966 V4S 80HP Johnson outboard motor that has no spark. I have cleaned the points and checked the plugs. I reset the point for .020 because they were off a bit but can't seem to get any spark on the output of the distributor. Can anybody give me a walk through of the wiring system and what to check ? Also there is a switch just to the right of the case where the points are that has a white wire attached to it. When I crank over the starter I have voltage on this switch . .what is this for?? Does it have something to do with the timing?? I have pics I can send if anyone can give me a quick walk through.
