1966 johnson 60hp magneto ignition burning rotors
leadpencil2
i understand its fairly common to see these rotors fail but i seem to be really going through them. 2 in one day on the lake, am i doing somthing wrong or is there somthing i can do to prolong a rotors life? any help is appreciated, this is fustrating.
Daviet
Re: 1966 johnson 60hp magneto ignition burning rotors
Are the rotors arching through to ground, are they melting?
leadpencil2
I beleive they are arching through to ground. There are visable signs of melting.
Daviet
Are they OEM rotors. Is the little brush and spring between the rotor and dist cap?
leadpencil2
They are OEM rotors, actually they NOS. I'll double check tonight but I beleive the Spring and brush are in place. Just a thought, as I am using NOS rotors, does anyone beleive that the plastic has broken down and maybe more sensitive to shorting out.
boobie
Put some dielectric grease on the mag shaft before installing the next rotor.
