1966 johnson 50 hp
marc whedon
I have a very clean 1966 Johnson 50 hp that i need a head. Can anyone tell me what year and horsepower range fit this model?
sutor623
Re: 1966 johnson 50 hp
If it needs a powerhead it ain't that clean Ski-bo-ski....
marc whedon
Plug was stripped out and a heli coil was put in very badly. Want to use it on a resto project.
marc whedon
doesn't need a power head just a head bad plug heli coil job, want to use it on a resto project.
1946Zephyr
There wasn't a 50hp built in 1966. There was the old Fat Fifty's built in '58 and '59 and the 50hp twin was re-introduced in 1971. Do you have a model number?
boobie
I've always used heli coils but there are other ways to repair a bad plug hole. Check with your NAPA dlr.
F_R
Give us a model number and maybe we can answer your question. There is no such thing as a 1966 50hp.
I used the solid threaded inserts to repair spark plug threads. You would need to remove the head and tap to receive the insert. You will need some epoxy on the insert to secure it in the head.
BTW - the 1958/59 Fat fifty is a V4, hence the reference to "Fat"
sutor623
By solid you mean like a Timesert?
