1966 Johnson 100 HP Meteor Starter
nic420
Where can one find a replacement starter for 1966 Johnson 100 HP Meteor. Is it Meteor or Golden Meteor?
Regards,
Nic
Evinrude Boater
Re: 1966 Johnson 100 HP Meteor Starter
Welcome to iboats nic. You can probably find one in a boat motor bone yard. You can have yours rebuilt if it's just wearing out. Take it to a starter shop and see what they can do.
nic420
The starter was missing when boat and engine were bought together. Saw on E-Bay a starter for around $63.00 but not sure if it will work for the engine.
Thanks,
Nic420
nic420
Are those the model the engines that has interchangable starter for a Johnson 100 HP Golden Meteor?
nic420
Can you interchange the starters for the following engine model numbers with a 1966 Johnson 100HP Golden Meteor?
1987 Doral Classic 200 Bowrider, 4.3 Mercruiser/Alpha One
1964 Evinrude Speedifour, 1963 Evinrude Starflite, 1965 Johnson 5hp and 1960 Evinrude Lark
tx1961whaler
answered in other thread.
Try not to post the same question in multiple threads.
