Re: 1966 Evinrude Fisherman 6 hp - Rebuilt carb - Still runs terrible!
Thanks for that! That was really informative. I followed his advice and set the cam and the roller. Mine was way off. While I was at it, I took another look at the points to make sure everything was good there. I put everything back together and ran it in a barrel again. It seems like it is running better but still far from good. I can keep it running if I feather the throttle but there still seems to be a good 3 second delay. I can get it to idle for about 15 seconds and then it will surge up and come down. If I feather the throttle, I can keep it going otherwise it will die.
I noticed two timing marks on the magneto and one on the flywheel so I got my timing light on it and had a look. My guess is that I want the one on the flywheel to line up in between the two marks on the magneto? Mine falls about 1/4 of an inch to the right. So my first question is, how do you advance or retard the timing on this motor?
Next, while it was running, I noticed the smallest amount of what appeared to be exhaust coming out of one of the holes on the face of the carb. If you look at the carb, it is the hole to the right side of the low speed needle. I found a picture of a similar carb and attached the image. It is such a slight amount, it's hard to see. That can't be good, right?
When I finished, I pulled the plugs and they were both black and soaked. I'm surprised that it was even able to run they were so wet.
Once again, thank you for your help. I feel like I'm on a mission to figure this thing out!
