1966 Chrysler 35Hp
johndoe
I love this forum, The more I read, the harder it is leave...<br /><br />I am a proud owner of a 1966 (maybe 67) 35 HP Chrysler, outboard!<br /><br />It runs good, but won't start... Idle is rough. I am very mechanically inclined, but outboards are new to me... I have the Clymers manual, on order, but would love any help or suggestions on this one... I am thinking, Carb rebuild kit to start, but really don't know anything about the timing.... It fires with a squirt of gas in carb, but won't stay running once that is burnt...?<br /><br />It's in good shape, and I am thinking about restoring or rebuilding the whole dang thing...?<br /><br />too serious for a weekend project??
K. Johnson
Re: 1966 Chrysler 35Hp
Had the same problem, installed an electric fuel pump. Problem solved.
steelespike
JD, Fuel supply problem.You should go through the fuel system from tank to carb.Watch for dirt water<br /> clean and rebuild as required.Check diptube tank vent Fittings.connectors filters,fuel pump,and carb.<br /> Its kind of nice to fix up an old motor just keep in mind It is an orphan and not known as the most reliable motor at its best.
