1966 Chrysler 3.5 hp
John Gagne
I need a lower unit seal kit for a for a 1966 3.5 hp Chrysler. Any thoughts on where i can get one? Also, can I remove and replace the drive shaft seals without removing the retainer? Thanks in advance..
jerryjerry05
Franz Marine might be able to find the parts.
You talking the prop shaft seals or the drive shaft seals??
You can try to remove the seals but would probably have better results if it came apart.
John Gagne
Both seals I think.
Noobie question- is it possible to remove the seal retainer without destroying them? If so, how?
jerryjerry05
Post close pics of the lower unit and the area where the seals need replacing.
