1966 80 horse evenrude
Eric Eberlin
Looking for advice on this oldie but goodie 1966 80 horse beauty. Starts okay But idles rough, With 2 warm cylnders, 2 cold cylnders. Reving it up it smoothes out and all cylnders get warm. Carb rebuild , new plugs and points and condensers and I still can only get about 1\3 speed at full trottle. I am guessing a cap and wires would cure but the wild price makes me hesitate buying. Compression test Was great. Any advice on next step and where to find uesd parts??????
rickdb1boat
Re: 1966 80 horse evenrude
Check the T-Stats. Sounds like one may be stuck open, not allowing the cylinders to fully warm up for proper combustion. Are you getting fire to the other 2 plugs when cold? Swap coils and see what happens.
Eric Eberlin
Yes I am getting fire(I suspect not full voltage) and the plugs are wet Thanks
BillP
I will ramble with my thoughts about this based on been there and done it:<br /><br />Which cyls are not making power at low speed...same carb or both carbs? If on one carb at least you know to work only on that bank. If on both carbs I'd say both rebuilds were done wrong OR it not at all a carb problem. This leads to fuel delivery or electrical. Have you played with the adjustable mixtures? Reeds are delicate so they may be the problem too.<br /><br />The motor should still run fast (but dirty) without the tstats in so I don't think cold is the problem. It may work that way up north in really cold water but not where I live in warm climes. <br /><br />This is an old motor, have you replaced the pump diaphram? Have you pumped the bulb when the motor is at full throttle? Check bulb, lines and connectors for air leaks.<br /><br />Is the motor backfiring...this is a sign of electrical issues. No backfire is generally fuel related. <br /><br />Getting spark at the plugs doesn't mean it is firing hot enough under compression. That motor has 1 external coil right? If so, any $20 automotive coil will work...just check the motor for a resistor or non resistor coil. Your motor may have red/wht stripped resistor wire instead. Just disconnect the resistor wire and use a coil with resistor if you want. I ran a 1965 Johnson 75hp this way 100s of hrs. <br /><br />The spark plug wires are SS and the wire rarely goes bad, it's the rubber and connectors. Check for cracks and use high temp silicone to seal if you don't want to spend big bucks. Distributor cap and rotor may be cleaned up but I've never had that last long.
