1966 6 hp fisherman Evinrude problem with power
patflans
1966 6hp fisherman
Hi all! I am really confused, I bought 2 years ago from the original a 1966 6hp Evinrude fisherman motor. I use it for moose hunting to get to the island, about 6 min and once a year for fishing during a weekend. My issue is, it seems to fall on one cylinder, I did a compression test and in both cylinders I have 80psi. I did a spak test with the spark tester and the light comes on on both cylinders. What am I missing?
patflans
Honorary Supreme Mariner
Very common to run on one cylinder.----Answer this question.-----Does the spark jump a gap of 1/4" or more , yes or no ?.------Or remove the flywheel and you will likely find 2 cracked coils.-----Luck if they have been replaced already.
oldboat1
Is the fuel fresh? Try the drop-cylinder test: Start the motor and remove one plug boot at a time. If there is no effect when one of the boots is pulled, that plug is probably not firing.
F_R
I don't care what the spark tester says, pull the flywheel and take a looksee. Dirty breaker points?? Cracked coils?? Bad plug wire??
Crosbyman
my latest fix on a 4hp was a bad connection inside the plug's rubber booth
due to corrosion the spike inside the booth was not making good contact
if all is ok under the flywheel (points cleaned- adjusted condensers ok and coils …. check the wires
you may have just a bad sparkplug ..they do go bad
JohnnyGuy
Also pull and check plugs, are they fouled? Sounds obvious, but worth mentioning.
A nice cheap spark gap tester is Lisle 50850.
I had purchased the inline one that lights up as you described originally. Now it just sits in the bottom of my toolbox.
Mohawkmtrs
...or you can go to an auto parts place (NAPA, etc.) and pick one up for about $8-$10.
