1966 33hp johnson spark issues
jjkwapis15
I have a 1966 33HP 2 STROKE / 2 CYLINDER. I did not have any spark when i bought the motor so I changed the points, condensers, and coils. Those are all new and I have spark in lower cylinder now but nothing in the top cylinder? I checked the plug wires and they are good. I was wondering if the key switch may have anything to do with that?
I was wondering if the flywheel may be an issue? Could that do it?
Honorary Supreme Mariner
Well it is NOT the flywheel.------The ignition switch would kill spark on both cylinders.------My guess is a wee bit of dirt on the points. ----Any evidence of tampering with cutout switch wiring ?
kbait
Did you set the point gap to .020" for each pointset at the high spot on the cam? You need to spin the motor 180 after gapping the first set, then gap the other one.
Chinewalker
Double check the ignition components you installed. All coil & condenser wires tucked out of the way so they don't rub on the flywheel hub? Points are gapped at .020" and CLEAN-CLEAN-CLEAN? Coil laminates are absolutely flush with the outer machined edge of the magneto plate? Spark plug wire ends are firmly seated into the coils?
Also, disconnect the kill circuit to eliminate that as a possibility.
oldboat1
^^agree. Also the connectors at the plug ends of the wires, inside the boots. (spike has to be in good contact with wire core).
jjkwapis15
No as I checked that and it works.
jjkwapis15
Yes with the guage that I do not know how to spell sorry. feeler but that is not the correct spelling of it.
jjkwapis15
I will try to disconnect that thank you for that thought.
