1966 1A EZ shift parts
Richmond2000
turns out my boat / drive is a 66 and NOT a 69 and that explains why parts DO NOT look correct for my unit
I have my drive removed and split and I would like a source and Part Numbers if possible for water pump / sealing up kit + drive to bell housing gaskets
thanks in advance
Ayuh,.... Unfortunately, the most common part number for that ole drive is NLA,....
No
Longer
Available,....
Richmond2000
No
Longer
Available,....
I found a dealer that has lent me the SIERRA catalog and I have found my part# from the sierra catalog
going forward it will get a Alpha one / MC1 transplant
when I am less cash broke
Richmond2000
if I am NOT off course I believe a gimbal assy from a MC1 will fit the current transom/engine bracketry and allow a MC1/ALPHA drive to mate up
Ayuh,..... You'll be way, Waayy, Waaayyy further ahead to buy a complete runnin' donor boat, 'n junk it for it's driveline to transplant into yer hull,....
I believe you'll find little to nothin', other than the Long Block motor is an easy swap,....
The transom hole in the hull will be Close,...
You'll be drillin' a few new holes, 'n grindin' the keyhole out abit too,....
You'll only be usin' maybe 2 of the current stud holes,... possibly 4, but I think they're wider on later models,...
The Alpha 1 is gettin' older, 'n cheaper, skip right over the MC-1s,....
Go for the Alpha 1, or Better yet, the Gen.II if ya can find the coin,...
The Gen.II is current production, that came out in '91,.....
Richmond2000
thanks I would like to do that but the orig idea came about because of a 74 MC1 complete from transom back was in KIJIJ for 400 but I missed it
yes it is common for 3.0L boats to fetch 800 to 1K with Alpha 1 but that won't happen until at least next year
how far forward does the engine need to go in an ALPHA 1 swap install my understanding is around one inch
