1965 sea king 6 hp lower unit seal
codykoke
I need to find a lower unit seal kit for a 1965 sea king (Chrysler) 6 hp outboard. Any leads are appreciated
robert graham
Re: 1965 sea king 6 hp lower unit seal
If you can remove your old seals and take them to a Bearing Supply store the odds are pretty good they can match it up. They'll have an OD, or outside diameter, and an ID, or shaft diameter and a seal thickness. You may even luck up and locate a specific seal kit for your motor. Good Luck!:)
