1965 johnson 6hp
Overkill72
i recently recieved a 1965 johnson 6hp outboard motor and have been in the process of working out all the little problems ( cleaning carbs replacing spark plugs) unfortunately while trying to start it the other day ( pull start) the main spring for the return for the rope unwinded (forgive my spelling lol) and i would wondering how one would go about putting this right????
SWD
Re: 1965 johnson 6hp
I have a 1969 Evinrude 6hp and had to replace the ring gear on it last year, which meant having to take the rope pull out. As far as I know, you'll have to remove the flywheel and then you gain access to the rope pull assembly and spring. Someone will surely correct me if I'm wrong.
Joe Reeves
(Manual Starter Cord Installation)
(This pertains to the vertical type of Manual Starters such as the 9.5hp and later 4.5/6/8hp models etc)
(J. Reeves)
1 - Have a pair of vice grips handy set so that they will grab the top of the starter spindle tightly but will not damage it.
2 - Using a large screwdriver inserted into the top of the starter spindle, wind the starter in a counter clockwise direction 12 to 14 turns, stopping so that the cord locking slot is facing the away from the engine.
3 - Lock the spindle in that position with the vice grips, letting the vice grips lay against the flywheel.
4 - Insert the cord as needed and make sure it is retained properly at that slot.
5 - Feed the cord out the starter cord hole at the front of the engine and attach the handle.
6 - Grip the cord tightly so that the spindle cannot spin around rapidly, then release the vice grips.
7 - Allow the cord to be withdrawn slowly around the spindle.
Overkill72
thank you so much joe!!!!! was exactly what i needed!!!!!!!!
