1965 johnson 60hp VXH-11C wiring diagram
Timt2011
got a 1965 johnson and am looking for a wiring diagram?
got the motor but the wiring was all cut and removed from the motor, I was able to get it running but am unabls to figure out how to hook up the generator to keep the battery charged and unsure if it needs to gointo a voltage regulator or anything of that sort befoer going to the batter, also howto hook up a stop switch to kill the motor...
i put in a starter selonoid and am able to start it useing a jump wire from battery tothe little post till i put a key system in it.
any help is greatly appriciated......thanks
p.s. The plug wires hang down...magnoto ignition?
F_R
Honorary Supreme Mariner
Yes, magneto. The generator was an accessory kit. This diagram is as close as I can come. Same motor, actually, but wire colors MIGHT vary (not sure)
Yes that uses a magneto.----The magneto is self energizing and does not need a battery.
