hi guys will try to explain as best. i have a1965 johnson with a shot gearbox so i put a good spare on off a later model evinrude that has a different design water pump and water tube layout but all fits still thou the engine isnt cooling.the later model has a different design of pump with three spouts due to it being fed via a pipe but the return water does not go back into pump like the original does is this why im having problems
