1965 Johnson 18hp FD-19 won't start?!?
WavesofChange
I am new to the forum so I will try to keep this concise.
Background: this engine has not been fired up in 20 years, I inherited a 65 Silverline from my grandfather all original and have rebuilt and fiber glassed in a new keel and deck/floor.
Parts Replaced: Fuel Tank, Fuel Line from Tank to Engine, Spark Plugs, Points, Condenser, Coils, Fresh Fuel 50:1, Water Pump, Oil in Lower unit, Battery
Inspected/Cleaned: Fuel lines, fuel pump and carb.
Troubleshooting process: Before attempting to start the motor I replaced all the above parts one for one by the book. I am not familiar with 2 cycle engines but I am fairly mechanically inclined. I expected some difficulty starting the motor for the first time in 20 years but am baffled at this point and need direction. When cranking the motor I have very strong power from the starter, fuel entering the cylinders but apparently no spark or perhaps a timing issue?. I am confused on that point though as all timing functions appear to be preset. Unfortunately my manual is not the best help. Any insights would be greatly appreciated. I am considering a marine engine shop as a last resort. But, am fairly certain I have overlooked a simple detail. Thanks
RCO
Verify spark first. It should be able to jump a 3/8" gap on a spark tester. Did you clean the points and adjust to .020 at the high point on the cam when you installed them? If you did, and still don't have spark you most likely have an issue with your kill switch or ignition switch. You will almost certainly need to go through the carb if it has been sitting that long also. Timing is a non-issue on that motor.
WavesofChange
Combustion!!! First, thank you for your insight, I adjusted my gap and replaced my spark plug wires as they did not pass my continuity check. Needless to say spark has been verified. I test fired the motor and it is firing, which is a relief. I have done some cleaning of the carb but clearly have a ways to go. Thanks again for the input and I will update the thread once I have it idling.
tomhath
Master Chief Petty Officer
After 20 years you probably need to replace or rebuild the fuel pump.
