1. YESSo I get around 8 volts at the coil with ignition on. The points are new and the condenser as well as the primary coil wire as I ripped the first one. The points is where I have a question: should they close all the way and then at their open position they need to be gapped .020? When they're closed they need to touch?
2. Do you have spark from the coil, before the distributor, yes or no?
