If you think you are confused, how about us? Stuff you are telling us just doesn't match. I can't think of any model with two black and two reds from the stator. Besides, the stator on your (supposedly) model has absolutely nothing to do with the spark. It functions solely as a 20A alternator to charge the battery.So I have figured a few things out so far. My stator wires don't match the diagrams. I have two blacks and two reds but should have two yellows and a red and blue. I think I have it hooked up right finally but still won't start. I also ordered and received a new resistor wire and a new throttle cable which is unrelated but mine is a goner. Any suggestions on what else to try? How many volts should I get at the coil?
It's time for you to post some pictures of just what you have.
EDIT: Voltage at the coil + should be approximately 12 if both sets of points are open and approximately 6-8 if one or both sets of points are closed.
