1965 Evinrude seal replacement?
oldcatamount
Re: 1965 Evinrude seal replacement?
A flat screwdiver will work. Just be careful prying on the surrounding castings. I use a thin piece of soft wood to protect the castings. You can also use coarse thread drywall screws. Drill a couple holes into the outer rim of the seal, thread in the screws and use them to lift out the old seal. A small slide hammer with the right jaws seems to work the best though.
abreen89
Okay great i didnt want to damge it or anything else before i knew what i was dealing with. I appreciate it.
