1965 Evinrude 6hp outboard
fish4444
Hi all, I'm a new member here. I just bought a 6hp Evinrude outboard ( serial # 6502m-eo8712) that almost looks like it's in mint condition under the cover and found out it was made the same year that I was born! Does anyone know the proper oil/gas ratio for this motor or it's approximate value? I was told that it was only used a couple of times and by the way that it ran it sounds like it was new! Good Luck Fishin! Rick
interalian
Value? No idea. But if you're planning on running it, you should put in a new water pump impeller. A 50 year old rubber pump will be well past it's prime and could fragment, causing problems with blocked passages in the water jacket.
boobie
Proper fuel/oil ratio 50:1. And I agree with changing the water pump.
ondarvr
Value varies a great deal by region, but a couple hundred maybe, if good. They were good motors though.
fish4444
Thanks for the advice! I'm going to order a manual and start looking for parts.
bspeth
I would go ahead and pressure test the lower while you are swapping gear oil and impeller. Clean the points and set the timing and it will be a nice fisher. Do this before you order your impeller is case you need seals in the lower,flat rate shipping.
