Re: 1965 evinrude 60 no spark
You have started at least three threads on this motor, with conflicting information. 60753A is indeed a 1967. Previously, you said it was a 60573A, which is a 1965
IF IT IS a 60753A, it is battery ignition, with points inside the distributor cap. And it must be connected to the wiring harness, and a charged 12V battery or it won't have spark. There is a special resistance wire built into the wiring harness, so don't gerry rig it unless you know what you are doing. And all that may be changed anyway, since you have subsitituted a car coil. See what happens when you start substituting parts?
