jbrow9.5hp
Thread starter- Joined
- Oct 15, 2010
- 15
Hi all,
Well, I rebuilt the carb and did a tune up. The engine finally starts, but I cant get it to stay running without the choke. I started with the slow speed needle at 1 and a half turns out and it would run for a few minutes with the choke fully out. I adjusted it in 1/8 and it wouldnt start at all so I decided to adjust it out. IT will start and sputter without choke for a few seconds, or if the choke is engaged it will run fast for a few minutes and then die. Please help! I came out with the needle more than 2 full turns, from seat. Other than not smoking so much and running a bit longer on choke, it still wont run without the choke! What do I do???
Thank you,
Joel
Thank you,
Joel
