1965 9.5 Evinrude-No Spark
deanbyrdbyrd101
Recently bought a 1965 Evinrude motor 2 cyl.I do not have any spark at plugs and have no idea what the gas and oil ratio is,can anyone please help me.
Chinewalker
Re: 1965 9.5 Evinrude-No Spark
Oil ratio is 50:1 (one pint TCW-3 rated oil with 87 or 89 octane gas).<br /><br />No spark is one of five things...<br /><br />- Points corroded or closed. Clean up with 220-grit paper folded over on itself. Gap at .020. If they're badly pitted/worn, replace - they're inexpensive.<br /><br />- Coils shorted out. Generally visible as cracks in the coil casing. New ones are available and fairly inexpensive.<br /><br />- Condensers shorted out. Inexpensive part, should be replaced as a matter of course.<br /><br />- Plug wires cracked or corroded at contact areas. Usually visible. Replace if any question - use metallic core plug wire - NOT automotive graphite core...<br /><br />- Spark plugs - if they look garbaged up or excessively burned out, replace them - another inexpensive thing to check off the list.<br /><br />It's a simple system and works well when set up right. Be sure to lightly oil the felt follower on the point cam to keep the point pickups from wearing. Your local library likely has a manual with basic maintenance stuff such as magneto service...<br /><br />- Scott
