marrage councelor
Thread starter- Joined
- Jan 2, 2011
- 15
I have aquired a boat that had not been in the water since '97. I am a first time boat owner with some mechanical skills. I replaced fuel lines, put in barrel, started but did not see any water. I made a makeshift way to force water through cooling system. Started engine and it seemed to run okay, water flowed. I pulled lower end to look at water pump. There was milky oil around the pump area. And after stopping engine the seep hole drained out milky oil. I "assmume" the oil seals are bad. I am asking oil seeping out the hole is not normal and I do need to replace seals.
I pulled the lower end and hooked a water hose to the water tube and wanted to hear the engine run. It started to run rough and priming the bulb did not help. I pulled the carb (by way of starter) and in the carb bowl there was something like cork in pieces around the lower jet. So I am "assuming" that rebuilding carb is the next step.
#1. Water Pump kit / milky oil seeping out the weep hole is not normal and I do need to replace seals.
#2. Carb kit a must, but it seems orfice jets where cork seal and bowl drain plug are frozen in there. Any suggestions on safe removal, or just clean up the best I can.
Seems like some pretty sharp mechanics in this forum. I have learned a lot and gotten confidence in taking this on.
Steve
Steve
