youngbuck007
- May 12, 2010
- 27
It's been sitting a couple years and ran good when it was put away. I just can't get it to even so much as cough for me now. What I've done:
1. Fresh fuel
2. Pulled plugs and checked for spark, all good
3. Took off the carb and completely cleaned/dried it with brake cleaner, reinstalled.
Yes, I pumped the primer till it was hard, pulled the choke out (and have tried with the choke in), it's in neutral and the throttle is set to start. I pumped the primer with the fuel line that goes to the carb off to make sure it got fuel to that point, which it does. I just can't get it to fire up, not even for a couple seconds. I tried squirting a bit of fuel into the carb a couple times and still nothing. Any ideas?
1. Fresh fuel
