1965 18 HP Johnson not getting full throttle
dpostman21
My 1965 18 HP Johnson is not getting full throttle, it appears that the square tube is spinning inside the throttle lever. See in pictures
https://goo.gl/photos/XdSSWRMzfV5TmLeG6 shows the slot which appears to move about 30% before actually turning the rod that foes to the top of the motor.
https://goo.gl/photos/aJy4tSUvJ1BPvYmh8 This is as far as it goes right now, seems like it should go farther???
https://drive.google.com/open?id=0B__F02102-ELblJhRHJybHFtNEk see notes on picture.
Any help as always is greatly appreciated.
There is a plastic pin in there that may be broken.---At one time they were made of brass.
dpostman21
I seen a little plastic (blue in color) on the shaft of the piece that runs up to the top of the motor. Sounds like a good possibility.
THANKS!!!
dpostman21
Thanks!! Do I have to pull flywheel off to replace? Just at a glance looks like i will have to take quite a bit apart to get to it. It broke flush so i fogured I would have to take it all aprt to remove broken piece.
Thanks for the help. Really appreciate the insight.
HighTrim
Yes, I can see your key is sheared off in there.
Very easy fix.
??--Did not look at any pictures.---You remove the clip up top.---Remove 2 small screws and the tower shaft is out.
dpostman21
Took it apart and indeed that plastic piece was broke off. Going to order one up. Thanks for the help!!
