1964 super sea horse 40hp questions
nitrotweaker
I have been helping a freind with this motor so we can do some fishin.I have the carb off and I cleaned it.We are also going to put some points on it.What gap should the points be at and where to set them.Also need to know the low speed needel at.Thanks again
Joe Reeves
Re: 1964 super sea horse 40hp questions
(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubber portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
spy1309
Those adjustments are done in gear? start ? or slow ?
tmcalavy
Set the carb needles to the baseline settings that JR supplied. Start it up, leave it in neutral and run the throttle up, then adjust the high-speed needle to best runninig position. Throttle down after it warms up and set the slow-speed needle. You will have to fine-tune each one a little in the boat with the motor running and in gear.
Joe Reeves
On that model there is no high speed needle valve. It has a brass jet located in the bottom center portion of the float chamber. Make sure that the jet is thoroughly clean.
The idle needle valve adjustment is performed with the engine running in neutral, as slow a rpm as possible, just encough to keep the engine running. Re-read my reply..... it'll come to you.
spy1309
The reason I asked is that I have same motor only 1960, when I do the adjustments in neutral by the time I am done when I switch the motor in the slow position it tends to drop the rpm s to low and die.
