1964 starflite 6 75hp ignition problem
Status
Not open for further replies.
Skottmyer
I recently purchased a 1964 thunderbird Cathedral hull with an evinrude starflite 6 75hp. The boat had not been ran in about 5 years, but when it did, it ran great.. upon starting to play with it, I tried to start her up... it puttered,spit, and backfired... so far that's been the best we can get... I have cleaned the fuel pump, the carburetor, replaced plugs/wires,and terminals. Battery is new also. All plugs are firing and compression in all 4 is close to 100.. I have no clue what else to do. The only other option I can think of would be the ignition timing... can somebody PLEASE help me with this.... very frustrated.
F_R
Honorary Supreme Mariner
No Title
So how did it get out of time? Did you have the belt off? Anyhoo, here is the procedure for that. And also of course,make sure you got the plug wires on the right plugs.
Skottmyer
First off, thanks for the response F_R you're the man.. this exactly what I needed. Hopefully this is my problem... I've never taken the belt off, but other than the ignition timing I have no clue what it could be... I've removed the carburetor and fuel pump to clean them, and they were as clean as they could be... if it's not the timing would you happen to have any other ideas? Btw, yes the plug wires are on the correct plugs. It almost seems to me that no fuel (or very little) is making it to the cylinders.
oldboat1
recall motor has points, condensers and distributor. may need to clean an adjust points; possible moisture/condensation at distributor cap/rotor.
Skottmyer
Are the points supposed to actually touch when they are closed... I cleaned them and noticed that there was a small gap between the points when closed.. I adjusted the points and closed them completely... was that the right thing to do? How difficult is it to pull the flywheel to check for a sheared key?
F_R
Unless somebody has messed with the flywheel, the key probably is not sheared. They shear as a result of somebody incorrectly installing the flywheel. Yes, the points must close completely and must be making good electrical contact when they are closed. But really, the setting is supposed to be open .020" at their widest open position. Do that, and they automatically will close properly.
You say all plugs are firing. That is the important question. Are they really? Will it spark a 1/4" open air spark gap? If not, there are specific troubleshooting methods. Points really shiny bright clean? Proper voltage getting to the coil? Distributor rotor not shorted through? (a common and sneaky problem).
Skottmyer
I don't mean to sound like such a novice, but how would I check voltage to the coil or if the distributor rotor shorted through? I do get firing from all plugs, but I doubt they are 1/4" gap. Is there a way to increase that gap?
Skottmyer
By the way would anybody know how to get a service Manual for this motor without spending $50?
The 1/4" gap is set up on a tester.---The sparkplugs are not used when doing this testing !
F_R
Every serious outboard mechanic has a spark tester, even if home made. The simplest one you can "make" is to stick a #2 Phillips screwdriver bit in the plug boot and hold the shank 1/4" away from a head bolt corner while a helper cranks the motor over. You can make a more elaborate one with a piece of wood and a few nails. Get creative.
You test voltage with a voltmeter (multimeter). If you do not have one, now is a perfect excuse to get one and learn how to use it. You can get them these days for about $10 or less.
Testing the rotor is not so easy. You generally do that with a very expensive coil tester. But what happens is the spark burns an almost invisible hole through the plastic to the shaft. In other words, the spark jumps through the rotor instead of being directed to the proper plug wires.
F_R
I was just in the other room, watching the tube and mind wandering about your question about the rotor. Y'know what? Electricity is not complicated. But a basic knowledge of how stuff works is always where you begin. Then you apply common sense.
Consider the distributor rotor. The coil produces sparks (actually pulses of electricity at that stage). Those sparks go to the center of the distributor cap, to the rotor. Then the rotor points to the wire that feeds the cylinder about to fire and sends the pulse of electricity on it's way to it. That's the "how it works" part. So now apply common sense. If you have strong sparks off the wire leading between the coil and distributor, but not out the other side of the distributor going to the plugs, then the rotor is prime suspect. Or a cracked cap. You can see cracks, so if none, suspect the rotor. No fancy testers required.
Hope this helps.
oldboat1
have the urge to tell you to keep it simple. Like F_R says, there are issues with a distributor cap and rotor that you can see (cracks, for example). You might also see carbon trails inside the cap which shows misrouted current. Clean with electrical cleaner from an auto parts store. Use of a hair dryer is an old trick if moisture is suspected -- doesn't hurt to try that after cleaning.
But I would stay with the points before doing anything else. Reset them if you haven't done so already, and try the engine again -- sounds like you closed them where they were supposed to be open.
Skottmyer
Does anybody know what the brush and spring assembly in the middle of the distributor do? Looks like a small (almost carbon) piece connected to a spring in the center of my distributor has broke off.. I've actually found the piece on online but have no clue how I would get the new one back in.. the distributor cap doesn't come apart
Skottmyer
Yes willyclay, I did disassemble the carb/fuel filter. Was incredibly clean
oldboat1
Good luck with the project. Recommend an online parts blow up to see the particular distributor in your model, along with the brush and spring assembly. marine engine dot com is pretty good.
F_R
The wire coming from the coil is connected to the socket that the brush and spring go into. The parts make the connection across the gap between there and the spinning rotor below. Putting the new one in is simple. Just twist it as you push it in. The twisting action tends to wind the spring up so it becomes small enough to slide in then once in place it unwinds to hold it there. And yes, it is carbon, and fragile.
Willyclay
Sounds like F_R has you well on the way to recovery with the distributor cap issue! I asked the question about the carb and fuel pump because there are "gotcha's" when dealing with both. The carb has a high-speed nozzle in each throat that must be perfectly centered. I found out the hard way that a factory-made special tool is required to make that happen. F_R should be able to help you with that also. The fuel pump diaphragm is subject to having pin-hole leaks which allows the motor to suck fuel into the cylinders and fouls up the air/fuel ratio controlled by the carb. Good luck with that great old motor!
Skottmyer
I'm going through the same thing now... I've found where to get a new spring and brush assembly, however I have no clue how to replace it... can't seem to take the distributor apart to install a new one.. I have a 1964 75hp evinrude starflite 6
GA_Boater
Please don't hijack a ten year old thread when you have a perfectly good thread right here. Moved the post into this thread.
You really need a manual if instructions are needed to disassemble the distributor.
Status
