1964 Starcraft Control Box cable replacement
Stonecrawdad18
Hi all!
So, I'm in the process of replacing the shifting cable on my 64 Starcraft, and ran into a bit of an issue- I've got the motor end all hooked up, but the end that terminates in the control box is the issues. When I took it apart, it has the actual shifter, with the teeth that interlock in a rectangular piece- this contains the end of the old cable. How do I remove that and get my new cable into that piece? Or, do I need to replace that whole thing? I sincerely apologize for my lack of correct names- this is definitely on the fringe of my skill set! Thanks for any and all help!
I can attach pictures when I get home if it helps!
jbcurt00
What brand motor? Outboard or I/O?
After you tell us what motor, I'll move this over to the correct motor forum.
Not really a StarCraft question, although its in an SC.
Welcome to iboats.
Until the move, or after, dig in, lots of great SC stuff in here
Stonecrawdad18
It's a '64 Evinrude big twin outboard! Sorry about that- wasn't sure if it should be there or here! Thanks!
boobie
Look for some set screws in the end of the piece with the teeth which when loosened will release it from the old cable. Install on new.
Stonecrawdad18
Okay! So there should be a set of screws similar to how it is installed on the motor end? The whole piece is so caked in grease that it's hard to tell what is where!
Chinewalker
They are likely recessed a bit and you'll need an Allen wrench to loosen them. Use a good, crisp new Allen wrench if you can, as a well-used one with rounded corners wills strip out the head on the set-screw in a hurry.
Stonecrawdad18
Thank you!! I got it installed, but I seem to be having an issue- it's really, really hard to get it to shift between forward and neutral, and basically impossible to get it to go into reverse. Is this something related to my install or something else? Before I had to replace this cable it definitely felt like it was getting harder to shift, so I'm thinking it could possibly be something in the motor? Thanks!
carl2782
Shouldn't be harder to shift if all you did was replace the cable. Sounds like maybe the bends are too tight, could you post a picture of any bends in the cable? Did you relubricate inside the control box?
oldboat1
Need to disconnect the cable at the motor, and see if the motor is shifting OK. Will likely need to rotate the prop a bit to get the gears to mesh. Match the cable to the motor.
If you know the motor is shifting properly, go back to concentrating on the box.
[ed. throttle at idle setting]
Stonecrawdad18
I disconnected the cable from the motor and tried to shift it by hand by pushing/pulling where the cable would do that, still seemed really difficult/tight. Is it a lubrication thing?
oldboat1
Well, could be a gearcase issue -- and could be nothing at all. Was it running ok in the lake, or not? (Maybe you are in process of getting it ready.) I would drain the gearcase if you haven't done that, and check for water -- look for metal shavings. More basic, if the motor is new to you, look for oil in there. Has the lower unit been removed? Might have a linkage or reconnection issue (shift rod). Hard to say, but sounds like the issue may be at the motor and not the cable box or cable.
Stonecrawdad18
Fairly new to me, but it was running fine in the lake- the rubber on the outside of the old cable cracked and wore away and I didn't notice, so then I couldn't shift it out of drive because of the faulty cable. Was running fine even then, though. Hmmmmm.
