1964 Johnson V4S-16 75hp overheating
Reista
image_225761.jpeg image_225762.png image_225764.jpg I've been through the outboard 100%, removed powerhead and everything, and the engine now runs like a champ but will sizzle water away the second you drop some on it. Infrared meter says 280 cyl 2/4, 290 on cyl 1/3. I have the motor sitting in a big tub of water (i know better than to run it dry) and it looks like it's chugging air for some reason when I start the engine. It has a Evinrude 75453A lower end on it, and I'm 100% certain that the water pump is installed correctly. There's obviously something I'm missing here, any ideas?
Reista
Took out the Tstat and the check valve and flushed motor totally, didn't seem to be any blockages- tstat housing was 100% dry (still had a little sand stuff in it from the last run from the previous owner). It's too late to get a trial start without a tstat so I'll update tomorrow if anything happens. Aslo found out that having the intake in the water isn't good enough as the water pump isn't self priming - so gonna go with a bigger can
Willyclay
Some members have reported after-market water pump impeller bushing failures which might explain no water being pumped. Possibly the key that drives the impeller failed or became disengaged. Good luck!
F_R
You might get away with removing the vernatherm element and it's plastic valve from the thermostat housing, but if you remove the other plastic valve there is a direct air path down to the water pump and it won't work. Same thing if you run it with the t'stat cover removed.
