1964 Johnson Super Seahorse 75hp Electromatic Ignition Problem
trampswan
Hello my name is Tramp Swan and I am mechanically challenged.
My outboard motor will turn over and if the stars are aligned right will start and run fine. But if it dies or I turn it off I get nothing but heart break when I turn the ignition key. The next day first time up it will turn over and sometimes start. If it doesn't start on first try then nothing when I turn the key again. Battery is fully charged and load tests great.
I'd really appreciate any tips or solutions. Thanks in advance.
F_R
Honorary Supreme Mariner
So, you are saying the starter won't even run to crank the engine? That is the easy fix, but first you need to diagnose the problem. First thing you need to check is the throttle position. It won't crank if set at too fast a throttle position. Second thing to check are the battery cable connections. They must be clean and tight. Don't just look at them, take them apart and clean shiny bright. If these don't get you going, you have two choices: Guess at it and spend money on un-necessary parts, OR do some voltage checks to find where the problem actually is. You will need a voltmeter (multimeter) and some electrical knowledge. If you have neither, you may get off less $$$ by getting some help.
trampswan
Thanks for the help and point in the right direction. Today I have no voltage meter just a circuit tester and another cheap one for battery charge and load. Tracing down myself is the preferred route but thought I'd put it out here just in case there happened to be any chronic Johnson super sea horse electramatic similar ignition problems with quick fixes.
F_R
We still don't know if you are saying it won't crank (starter won't run to turn the flywheel problem) or if it cranks (goes 'round and 'round but won't run). Two entirely different subjects.
trampswan
It won't crank after the first attempt of the day. Everything tests OK from ignition key to battery and from battery to the solenoid. It will crank, start and keep running when jumpered from positive post on solenoid to starter with key in on position. That would seem to this novice to indicate the solenoid as the problem. Just seems strange that it reloads overnight for one crank only in the morning.
F_R
I still say, check throttle position. Related to that is the safety switch that won't allow starting at high throttle settings. You need to check the voltages on the two small terminals on the solenoid when it is in won't-crank mode. When you turn the key to start, normal is battery voltage on one terminal and zero on the other one and starter runs. Zero on both is a problem of not getting voltage from the key switch. Battery voltage on both is a defective or open safety switch. All bets are off if somebody put a car solenoid in there.
trampswan
Thanks for your patience. There is voltage on one solenoid post but not the other when key is on but it will not start (unless jumpered direct from post with voltage to starter). The starter throttle for when the motor is in neutral has been place at its lowest position and at higher positions. That seems to have no effect. It doesn't crank. i have not been able to locate a safety switch.
F_R
I am speaking of the two small terminals on the solenoid. Are you telling me that is where you have voltage on one and not the other? If answer is yes, does it click when you turn the key to start? If it does click, but not run the starter, it probably is a bad solenoid. Well, actually if you have voltage on one but not the other and it does not click, that could also be a bad solenoid. Safety switch is on the side, operated by the armature plate (the plate that rotates when you work the throttle)..​​​
