1964 johnson fd-18 wont throttle up
allegany23
Hello all, Im looking for some advice on my 18 hp Johnson. My motor starts up just fine (1 or 2 pulls) and will idle all day but when put in gear to throttle up it has no power and will just spit and sputter until you go back to idle where it continues to idle fine. The motor never stalls. I have had the carb cleaned and rebuilt so my guess is that's not the issue. Anyone else ever had this problem ? Maybe a fuel issue? Thanks
boobie
Do a cylinder drop test on it to make sure it's running on both cylinders. Also check your throttle linkage to make sure the carb is opening up.
allegany23
I did both and both cylinders appear to be firing. This motor is very easy to start which makes me believe I don't have a spark issue
allegany23
I have also noticed that my glass bowl has trouble staying full and will drop below the intake at times. My fuel line going from the tank to the motor does not have any leaks I have checked that.
lindy46
How's compression? Will it run WOT if you pump the fuel line bulb?
allegany23
I have not tried pumping the bulb while running it but I will do that. I can't remember the exact numbers for the compression but the cylinders were both over 100psi and maybe only 5psi difference
lindy46
If it runs ok when you pump the bulb, you most likely have a weak fuel pump.
Honorary Supreme Mariner
Filter bowl does not need to stay full when motor is running.---Does spark jump a gap of 5/16" on both leads, yes or no ?
allegany23
Thank you for the tips I will try all of these on Monday when I get a chance and will post back to let you know what I figure out
allegany23
Spark jumps gap of 5/16 and both cylinders are firing the same on drop test. Tried priming fuel bulb and no change bulb just built up pressure till I couldn't pump anymore
allegany23
Also after running both plugs are very black and wet. I just replaced both plugs
kbait
High speed needle may be set way too rich. Needle coming out of carb bowl should be turned out 3/4 turn from gently seated, and adjusted from there at wot.
allegany23
I don't believe this motor has a high speed needle. its more of a drain plug in the carb bowl if it isn't tight fuel leaks out. The only adjustment appears to be the lean/rich needle at the top of the carb
allegany23
anyone think this could be a reed valve problem maybe not seating properly ? I took them apart and cleaned them but maybe I need to clean the reed plate more
tomhath
Master Chief Petty Officer
Sounds like it's running too rich. Have you checked the float height? It's also possible someone replaced or otherwise tried to enlarge the main jet.
allegany23
When I had the carb rebuilt I don't believe the main jet was changed so that could be a possibility. I got this motor in a trade and wasn't told about it having any issues and it has never ran right for me. The float was replace and it appears to lay flat when held upside down.
allegany23
I thought that the motor was running way too rich also it smokes a decent amount, black oily fuel comes out of spark plug holes at times and also barrel get very thick black slick on water which is what made me think it is running way to rich.
