1964 Johnson FD-18 18 HP will not throttle up
allegany23
I have a 64 Johnson Fd-18 18 hp that will not run at WOT. When I go to throttle up the motor will surge and then bog but wont stall. Motor just spits and sputters with no power until you go back to idle. Motor starts first pull and idles great. I have put the same fuel pump from another running outboard on and no change. Carb has been cleaned and rebuild. I have tested spark jump and spark easily jumps 5/16 with blue spark on each lead. Cylinder drop test performed and I get same result on both cylinders. Also if magneto is turning when I twist throttle does that mean my timing is advancing properly ? So I'm getting good spark to both cylinders, Carb is clean and functioning properly, also fuel pump is good. Anyone else have any advice I'm out of ideas. Thank you
oldboat1
You mentioned the carb a couple of times, and you know we're going to ask how you cleaned it. So....how did you clean it? Good you were able to test out the fuel pump with another one.
It could be the link and sync setting -- carb has to start to open when the wheel just touches the mark on the cam.
[ed. compression OK?]
allegany23
I had the carb cleaned and rebuilt by a marine mechanic (new gasket/float kit), the motor would barely start before that was done and now it starts first pull. I have a 68 6 hp evinrude that runs like a champ and in doing research the aftermarket fuel pump is the same on both. ​I put the evinrude pump on it and it ran the same. The mechanic also tested the compression and it tested 100psi on both cylinders. I tried to see when my carb was opening related to the mark on the cam roller. It seemed that my throttle may be opening just a split second early but I don't believe that would be enough to throw it off.
oldboat1
think you should talk to the mechanic about those symptoms (shouldn't leave the shop like that, imo).
allegany23
I did talk to the mechanic and he said it could be a reed valve not seating but I'm not getting any other symptoms of a bad reed no spitting back out the carb and it starts way to easily in my opinion. I don't have anymore ideas
tomhath
Master Chief Petty Officer
I'd start over with the high speed mixture adjustment. I believe it should only be 3/4 turn open after gently screwing it in until it stops.
Also, how do the spark plug wires look? At lower RPMs the voltage to the plugs is lower, at higher RPMs the higher voltage might be arcing through bad insulation.
allegany23
There is no high speed mixture on this motor it has the fixed high speed jet. Spark plug wires and boots could prob use replacing I know that there is electrical tape on each of the wires but I did not inspect what was underneath as I was getting good spark when testing the gap jump. wouldn't the arcing cause the motor to stall ?
allegany23
also one other thing is that the motor has no problem reving up in neutral when I disconnect the tank and let it run out of gas. (As it runs out it will rev up and sounds fine).
oldboat1
some just quietly shut down when the gas runs out of the system. Others rev as the feed leans out. You might check your choke linkage and plate to make sure the choke fully opens while running. Actually, throttle plate too -- make sure it's fully open when throttled up.
allegany23
ok I will check those out. I inspected my plug wires tonight and when I took the electrical tape off the plug boots pretty much pulled right off the leads they may have very well been arcing. Now that I remember I could barely hold onto the plug boots during the cylinder drop test due to getting shocked.
AlTn
pull the boots and terminal ends off the wires and cut 1/2" or so off the wires and reinstall the terminal ends and boots...better yet, just replace the wires, terminal ends and boots with new....wires are 7mm solid core wires...wires screw into coils as the spikes in the coils have a slight twist to them
