1964 Johnson 40hp stuck in reverse
cortall
Today I attached a new shift cable to the manual lever for reverse, neutral and forwards. I soon found that after testing it a few times it would not move out of reverse. I detached the cable and EVEN then it would not move out of reverse no matter what I could think of. It DID work fine (moved that is) before I fiddled with attaching a new cable. Is it just something simple I need to do or am I just bad luck and broke something internally?
F_R
Honorary Supreme Mariner
If you have not done so, back the throttle off to slow idle position. You cannot shift out of reverse if throttle is set too high (there is an interlock device)
cortall
I tried that but no avail. I see where the lock would be and how that works with the throttle, but none of that is the problem. Seems to be something else
hardwater fisherman
Try spinning the prop while shifting. And as said make sure the throttle is set to the lowest possible setting.
F_R
You could have a stroke of bad luck and the clevis is broken (under the powerhead). They did that, and when it happened you couldn't shift because the broken part would jam up against the "wall".
F_R
No Title
I have no way of knowing from here, just speaking from experience. But this is the part I'm talking about.
cortall
Alright thanks guys! well I'll try these this weekend and hopefully it's nothing bad!
