Get a carb kit with float and rebuild. I Use spray carb cleaner to clean out all the passages. I usually soak the parts in acetone and then blow them out real good. When rebuilding, be sure to remove the core plug in the top and clean out the idle circuit beneath. Check the orifice that the needle valve goes through and make sure it is not chipped or broken.
