1964 9.5 hp johnson LU gear oil
baja32
What gear oil do I need to fill my 1964 9.5 hp johnson lower unit with??
Thanks in advance
oldcatamount
Re: 1964 9.5 hp johnson LU gear oil
Any "quality" brand lower unit oil will be fine. Heck, I'm using Mercury oil in mine right now. I have the same motor and I'm putting a new ignition system in it as we speak! Great motor (little tough to work on though because of the cowling and the casing).
kfa4303
Banned
HI baja82. yeah the brand isn't as important as the weight of the oil. Here's a pic of what you need.
Oil:
http://www.boatline.com/product_photos/41732.jpg
Pump:
http://images.search.yahoo.com/imag...i=11ogqmlel&sigb=12rlbddru&.crumb=4OUuQ0g0meA
There are many different brands and you can get it at Wal-Mart and/or marine supply stores. You'll probably want to pick up a pump while you're at it for about $10. They should sell them right next to the oil. One quart sized bottle should fill your LU several times. Here's a link on how to change it too. Good luck.
http://www.takeem.com/blinds/lower-unit.php
