1964-65 MeteorII
1sttimeowner
Can anyone tell me what the sparkplug gap is for a 90hp johnson meteor II,the year is 1964-65.And also there is a switch by the dist.with 1 wire going to it,and it looks like there should be 1 more wire across from it but I can not seem to find a place where it should connect to?
F_R
Honorary Supreme Mariner
Re: 1964-65 MeteorII
.030" That is the safety switch, keeps you from starting the motor at high throttle settings. Just one wire. The other terminal is because they use a stock switch off the shelf. It could be used in other applications requiring two wires.
