1964-65 evinrude 9.5 sportwin
Big Ol Johnson
it starts strong, and then after about 30 secs it starts to run rough then dies, i dont know how rich to run it when im running it on 50:1 or maybe i need to turn up the idle speed idk
Scott06
Get it to whe u can keep it running can try to turn up idle speed. What do the plugs look like, if black you're too rich ? Can you keep it running if you choke it a little? If choking it helps would think you need to richen mixture or the ake carb apart and clean. Do you have good spark? For $10 you can buy a spark gap tester should be a nice clean blue arc.
oldboat1
Try pumping the primer bulb to keep it running (fuel pump check).
Crosbyman
http://www.leeroysramblings.com/OMC_9.5.htm
take off the cowl for a tets run if ok it may be inhaling it's own exhaust known issue on the 9.5
is this a newly acquired motor or one stored for years....
could be lots of things incl coils condensers heating up read leroy's article
F_R
Honorary Supreme Mariner
Lots of issues with that model. If you are trying to get a nice slow idle, that is one of the issues. They shook and vibrated so badly at idle, they would stall if too slow.
And you cannot run them in a barrel with the hood on.
Big Ol Johnson
yeah it shakes real bad at low idle, also it is a newly aquired motor but has been stored for a while, also i am running it 50:1 should it be 40:1 or 32:1 or what, also i dont think it is inhaling smoke i tried running it with the cowl off and it still died
Crosbyman
sometimes they shake so badly the literally shake the choke knob shut and choke the motor keep the choke open manually if you have to
btw tank vent is open ... yes ?
Big Ol Johnson
it could have been closed but i will make sure it is open now
.... think it was open however
