1964 60 Horse Compression in PSI?
pen-xv
I did a compression test on my '64 Johnson VX-10S 4 Cyl 60 Horse. I had a consistent 60 PSI across all four cylinders. My question is, is this an acceptable amount of compression for this engine? Consistency is a good thing, but this motor is so old, is it possible that they're all consistently low? 60 PSI seems a bit low, even though it is a very old motor...
F_R
Honorary Supreme Mariner
Pull the bypass covers off the sides of the cylinders. You will be able to see one side of the pistons & rings. Pistons should be smooth and clean, and you can poke at the rings to see if they move in the grooves (they should), or are stuck in the grooves (they should not be)
