1964 40 hp
hyspenc
Hi guy's
Would like to know the right oil gas mix for a 1964 40 hp sea hores
Modle RDS-26S
Serial C-397061
I have been using 50:1
should i reduse with the synthatic oil's avalible,or just keep it like this or has it been wrong as i have noticed in a post about a 35 hp that 1964 was 2 diff ratio's 20?:1 and 50:1
Thanks again
F_R
Honorary Supreme Mariner
Re: 1964 40 hp
50:1 is the correct mix. Just make sure you use TC-W3 outboard oil, synthetic or regular--either one will be fine. You will get less smoke and oil slick from the synthetic and it is bio-degradeable.
hyspenc
Re: 1964 40 hp
Thanks much FR
This is not a realated question but i know you will have the answer
As i was getting ready to install new points i noticed that one of the wick holders was missing i now only have one left should i replace it (dumb qustion)
or can i get by with only one wick?
26.95 o.m.c. part.
sorry to side track post.
hyspenc
Re: 1964 40 hp
Thanks tx
You know i never thougt to check out the parts catalog i have for the engine.
It also tells you part # and quantity.
Thank's
hyspenc
Re: 1964 40 hp
Well after checkng part's list, it shows part #510188 as one per assy.
Well there are two set's of point's on engine so i take it there should be two wick holder , does that sound right.
Thank's guy's.
F_R
Re: 1964 40 hp
There is only one wick and only one cam to lubricate. Putting it that way make more sense? Anyhoo, there is only one triangular boss on the armature plate for holding a wick holder. One it is.
samo_ott
Re: 1964 40 hp
Thanks much FR
26.95 o.m.c. part.
$27 for the wick??? WOW!
F_R
Re: 1964 40 hp
WOW, I reckon!! I missed that one. The clip is $37 and the wick is $3.50. But they give you a free wick with a new set of points. Wierd.
Tim Frank
Re: 1964 40 hp
Oh oh, am I really going to disagree with two of the true experts in here??
Actually, there is probably a rational explanation that explains all....
I can remember as a kid being entrusted to mix the gas for our 1964 Lark 40HP. Knowing how much boot would have been in my **** if I messed up, I was meticulous (or as meticulous as an 8 year old can be)....and can still remember (permanently burned into my hard drive :)) 1/3 pint per gallon....or 24:1....and this was right from the OMC manual.
I know that FR is not going to be giving out an incorrect mixture value....so, am I having a memory meltdown, or is there something else at play?
hyspenc
Re: 1964 40 hp
the wick holder part # 510188,is $26.90 from evinrude link from this site.
I know the wick comes with point set i have two.
I 'am taking FR suggestion of there being one cam and one oiler.
Now back to the origonal post 24:1 or 50:1:confused:
tx1961whaler
Re: 1964 40 hp
From the FAQ, by chinewalker:
POST-1964 JOHNSON/EVINRUDE/GALE - The official stance on 1964 and newer OMC engines is to run them 50:1 and it's a good rule of thumb to follow on the bigger motors. OMC also renegged on the late 1980s 100:1 recommendation on the smaller (4-35hp) motors, bumping them back to 50:1. I've found that the smaller (3, 4, 5, 6hp) motors from post 1964 up into the mid-1970s may appreciate a bit of extra oil as they still have some bronze sleeve bearings. I run 40:1 in my '72 4hp, as I have a pile of holed blocks, burned cranks and twisted rods that were run at 50:1.
1960-1964 JOHNSON/EVINRUDE/GALE - 18hp and up can run at 40:1, as they are mostly jeweled motors at this point. Anything smaller run it at 24:1.
Pre 1960 - any size, run it 24:1. If it's used for racing or high performance, double up the oil...
hyspenc
Re: 1964 40 hp
Thank's tx
For that informative post,
i think i'll try the 40:1 and see if it make's s diffrance.
cheer's:)
