1964 3.5 Wizard Shaft Seal
spirtS niggeB
I've got an old McCulloch made Wizard up an running, but after using it I find the gearcase oil to be milky with water in it. I'd like to replace all the seals in the lower unit, namely the propeller shaft seal, but I have no idea as to what I can replace them with. I've never really done anything to lower units besides oil changes.
Any input?
brim_buster
Re: 1964 3.5 Wizard Shaft Seal
some times they come with the impellor kit. I thought my evinrude kit had it in there. I just looked at the breakdown and the only seal it showed was behind the shear pin behind the prop.
F_R
Is that the water cooled motor by McCulloch? Pretty simple and straightforward. I took my parts to the local bearings dealer and he matched up the seals with no problem.
