Ayuh,.... Welcome Aboard,.... What motor ya workin' on, anyways,..??
Exhaust manifolds/risers and their gaskets.
How much water in the oil? Tablespoon or a gallon? Makes a big difference.
A small amount of water may leak past the rings after a while, but if you have major water in the oil (Very High oil level on the dipstick), chances are almost 100% you have a cracked block.
Thanks for all the replies you guys,
Not sure the exact amount, but the oil is very milky, so I know this is not good, the # 4 plug was the only one wet with water, upon removal of the head about 1-1/2 cups water on top of piston. Gasket appeared to be just fine. I need ideas of which areas to examine closely.
Thanks again, Audie
Ayuh,.... Then go with Tilliam's Idea,...
Pull the riser off the manifold, 'n see if that gasket is leakin'...
Just curious guys, if the water was laying on top of the piston, how did the oil get "very milky"
If the riser/manifold gasket leaked, all you would get out of the riser is about a cup and a half. That's on top of the piston.
Now where did the water come from that caused the milky oil ?????????? Head gasket is what everyone always hopes for, but seldom if ever is. Remember the Mercruiser Service bulletin on water intrusion?
Drain the cooling system, isolate the block from the manifold and water intake from the drive, and pressure test the cooling system to around 15-20 psi and see if it holds pressure. If it doesn't you might get lucky and be able to hear the leak. If it's internal, you should be able to remove the oil cap and hear it in the valve cover.
I'm not Ron, but if you already have it apart, it's too late to troubleshoot. Now you put it back together and see what happens.
Personally, at this point, make sure the head and block aren't warped. Put a new head gasket on and torque the head. Then pressure test the block and see if it holds. If it doesn't, something is cracked. But at least you don't have the engine all back together to find out it still leaks.
I got the gaskets, just now noticed the exhaust elbow is rotted out internally! Now i feel really stupid! The ports between exhaust and water are no longer separate due to a large rotted hole, a trained eye would have noticed immediately. The block appears to be just fine.
I'm gonna kick my own butt and start looking for an elbow.
Question? Is this the reason for all the water?
