hoffmanuno
Thread starter- Joined
- Jul 23, 2006
- 82
I have a 1963 Merc 850 I restored. I took off the lower unit to torch off the prop hub (it had sat unused for over a decade), and had a shop install new prop seals. Before this, it shifted into rev, neu, and forward fine. After getting it back and putting a new impeller and driveshaft sleeve and seal on, it now spins freely in reverse. I took an old shift rod off a merc 650 to align the cams, and it worked fine. With lower unit off cam clicks from forward, to neutral, and they work fine, but when you turn the shift shaft into reverse the prop spins like it did in neutral. This is all the same when it is bolted to the outboard and using the shifter on the boat. I havent tried shifting it with the motor running yet. Reverse just doesnt seem to engage anymore no matter where you turn the shift cams when off the outbord using the spare shift rod. Could heating the prop, and we had to heat it up to remove both the prop and hub, have caused the reverse gear to stick inside? There were no metal shavings in gear case before or after and it shifted fine before removal and heating? Im thinking reverse is stuck and may shake loose if I run it. Any ideas?
