1963 Johnson seahorse 40 hp
robbieluke
My son just purchased the boat, it runs but won't go. Is there a neutral safety switch or something? He went to put new oil in it but took out the wrong screw, he said that it appears to be spring loaded and had a hard time getting it back in
could this prevent it from actually going ?
No-----Classic case of a motor running on one cylinder.----Make sure you have spark on both leads.----Spark must jump a gap of 1/4" or more !
F_R
Define "won't go". Not at all or what? Does it seem to be "slipping" like spinning your wheels on ice?
todd281
If this is a standard shift, the "wrong screw" that was removed cold be the pivot pin that holds the shifting lever. then you will have to open up the gearcase and make sure that it is installed properly.
Yes he took out the shift cradle pivot pin.----Not the first to do , nor the last.----This mistake was made 50 years ago.-------These motors are well built and legendary in quality------That mistake will still be made 50 years from now.
F_R
No need to take it apart if you get it back in and it shifts forward-neutral-reverse correctly.
Chinewalker
A fine point awl does a good job of centering the clutch fork hole. Usually a two-person job as one person gently moves the shift handle back and forth while the other sights on the hole in the skeg. Once you see the fork's hole in the skeg's hole, use the awl to align the two, then stick the fork screw back in there.
As for the running issue, more info is needed, as noted above.
