1963 johnson 75 hp needle bearings
jrporath
I'm changing seals and my impeller on a 75 horse johnson. I need to pull the bearinng in the housing to the pump and the housing underneath that supports the drive from my power head, I think a piolot bearing puller would work but.... the inner diam. is 1inch and outer is 1-1/4. my puller is not that big. Any suggestions? Thanks.
R.Johnson
Re: 1963 johnson 75 hp needle bearings
Is that bearing damaged, or why do you need to remove it?
jrporath
no damage yet, but I want to chage the seals behind them in both housings.
F_R
You lost me. Are you speaking of the drive shaft seal below the water pump plate? Doesn't it come out from the top without removing the bearing? Or not?
I do know that some of the prop shaft seals won't come out without removing the bearing.
You should know that a needle bearing can only be pressed on the numbered end. Pressing or pulling on the other end will ruin it and it must be replaced. In other words, better have a new one handy before removing it.
Evinrude Boater
There's a seal below the water pump but all you need to do is unbolt the bearing carrier. If you split the lower gear case there's an O-ring. Check out the exploded diagram on the BRP web site for a 1968 85 hp and quote the item number you want to remove.
