1963 Johnson 18 hp exhaust leak?
igothefunk1224
I have been chasing this issue for awhile now. Good compression/carb kit (had carb apart multiple times). Starts and idles fine but just doesn't want to rip @ WOT. Removing the hood does help some but its still not hitting at full power. I have tinkered with the low and high speed to no avail after screwing out the recommended turns. My little bit of searching is pointing towards a possible exhaust leak. I attached a few pics of what I found after removing the powerhead. 1st pic is under the powerhead where the shaft goes in, the 2nd is a removable plate at the top of the leg where the engine mounts. Any ideas what is causing this?
Honorary Supreme Mariner
Do you have spark on both leads that will jump a gap of 5/16", ----Yes or no ?
Next is a compression test.-------Report the actual numbers.
igothefunk1224
Compression is good checked that already numbers were in the 100's somewhere and within 10% of each other. More looking for a reason why I have this white sludge built up under the powerhead. -Thanks.
tomhath
Master Chief Petty Officer
Did you put a tachometer on it to see how fast it is turning? I believe WOT on that motor is only around 4500 RPM
