1963 Evinrude Sportwin 10
75sting
Hello everyone, I just purchased this motor and was wondering how to set the points. I know the gap is .020, but I have never set points before. And I just ordered the coils, points and carb kit for it which should be in on thursday. I am also looking for a complete tiller handle for it and the steering bracket. Thanks to all for the help.
Model - 10302D
Serial - E1035A
AlTn
Re: 1963 Evinrude Sportwin 10
try the Top Secret Files at the beginning of this forum....aslo...google.. Duckworks Max Bringing a 1956 Johnson 15 hp. back to life...it's not the same exactly as your model, but close enough to help..disregard the pressure tank part as you have a fuel pump...using the search feature on this forum...type in "setting the points" and you can research...the parts you need...in my recent experience, you'd be well served to just buy a parts motor that has what you need with maybe the lower unit or powerhead messed up, look at marineengine.com, find your year and hp...look up parts prices for say...head screws...armature plates....carb bowls and filters..fuel connectors..etc...they add up quickly
Joe Reeves
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubbing portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
(Magneto & Driver Coil Alignment)
(J. Reeves)
To align the coils properly, have the metal vertical portion of the coil yokes aligned with the inside edge of the bevel that exists on the top portion of the aluminum seat upon which the coils sit. This creates the proper distance between the coils and the flywheel magnets. Faulty alignment creats friction and the yokes of the coils heat up, turn blue and expand.
